Koledzy ... pomocy
"Lambda Regulation Row 1 od 0.97 - 1.03 na biegu jałowym. "
U mnie Row 1 i Row 2 ta wartość na jałowym jest poniżej 0.5 :/ Czyżby sondy lambda poszły ?
oto bledy z alfadiaga
Failed Component Code: Altitude Sensor
Fault Symptom: Above Maximum Limit
Warning Lamp Status: Warning Lamp Illuminated
Fault Test State: Test complete for this Error or not applicable.
Fault Code Storage State: Error Present at time of request
Event Count: 64 count
Filter Count: 0 count
Environmental Condition One: Engine Speed: 24 rpm
Environmental Condition Two: Standardised Engine Loading: 29,25 %
Environmental Condition Three: Engine Coolant Temp: 47,8 °C
Environmental Condition Four: Air Temp: 12 °C
Environmental Condition Five: Throttle Valve Angle: 2,502862 °
Environmental Condition Six: Battery Voltage: 13,4706 volts
Failed Component Code: Turbo Regulator Control
Fault Symptom: Circuit Open
Environmental Condition One: Engine Speed: 23 rpm
Environmental Condition Six: Battery Voltage: 13,2822 volts
Failed Component Code: High temperature warning light
Warning Lamp Status: Warning Lamp not Illuminated
Pali mi się oczywiście marchewka, auto ma muła i pali prawie 20 / 100
. Dodam że mam V6 TB
