    Ramki Alfaholicy
Chiptuning.
I would love to know the effect of changing the stock IC to the 1.75 one. It should be larger and more efficient. In ASO about 950 zł, I think. Or maybe it even plugs & plays?
It’s a bit bigger than in the 1.4 MA - length 573, height 130 - core thickness 50 mm, and the one from 1.750 is 630/110/80.
It’s a bit bigger than in the 1.4 MA - length 573, height 130 - core thickness 50 mm, and the one from 1.750 630/110/80.
Fits without problems but you have to buy it together with hoses i.e. elbows from the IC 1.75
I remember someone worrying about the durability of the 1.4 MA engine .. well, as you can see there is plenty of margin ..
395PS 458Nm..
attachment.php
Source...
http://forum.nitrous-advice.org/viewtopic.php?f=6&t=7342
engine shaved
modified intake turbine
valve train 10-20k
Nobody would do a 10-20kkm mod - no jokes, durability cannot be judged in any way - here most depends on the user.
1.4 TSI with no modifications to the crank system is tuned to 260PS, so 250 PS 1.4MA without overrev should endure.
And isn’t the MultiAir at the highest power levels factory-shut? I heard from a tuner that such versions existed.
Certainly not TSI on the stock turbo; physically impossible.
I’d like to see AFR and EGT values in mid-range RPM.
Same for the 170 new injectors turbo intake bottom to reach, you can push to 300 hp 1.75 TBI max, what you can extract from the stock charger is at most 280 hp
Sent from my QUANTUM_2_500 using Tapatalka
But I’m talking about the pillar, not the hardware, read with understanding.
That’s probably a track version, so it likely has a cage, for daily driving it would be poor, just look at the torque curve vs. stock, it was probably trimmed in the program because the gearbox wouldn’t withstand 450 Nm from 2000 rpm ;)
and I didn't click the link..
so in that case it has a decent turbo lag for daily driving, on the track it would be a little beast with proper suspension and a cage
And how does the QV handle the chip in the long run? I know it revs around 280 horsepower, but would such an intervention not shorten the life of an already stressed engine?
After all, after engine hardware modifications they make this little car into 330 PS and 460 Nm.
I don’t understand these fears about modification; in my previous car I increased the power by 55 PS compared to stock and torque by 90 Nm and drove like that for over 100,000 km. Chips on a stock engine are only freeing the reserve that the factory left for warranty reasons.
Open the link, and you’ll see the cause of that turbo lag – a much bigger turbocharger; if you want power at the top end you need something to blow and fuel, and the ability to remove exhaust gases – it’s a system of interconnected vessels, and from a small engine like a 1.4 it’s hard to generate that much exhaust gas to wake such a turbo quickly.
you don’t have to explain to me where turbo lag comes from because I know ;) I’m just stating that for daily driving where you use the full rpm range it’s a mediocre experience to drive it, it lags at low revs and suddenly after passing a certain amount of RPM it rips your ears off :) on the track, while keeping high revs, it would be interesting all the time.
Ok, I’ve decided - do you know any specialists in Wrocław who handle this properly? Because unfortunately my GoodHope refused me due to lack of experience with this engine. To Cinka it’s far for me, but if there’s no good person in the south of Greater Poland Voivodeship and in Wroclaw, I’ll ride there.
From Wroclaw it’s not far to Cinka. On Saturday I’m already going there with three cars - this time I’m doing my 159 1.75 TBi, previously it was Jule 1.4TB and 159 1.9JTDm a few years ago - I’ve always been satisfied (and I think everyone who had work done by him).
That’s something to ask in the well-known topic in the 159 section :D.
The number of group (and not only) chip jobs done over the years for many forum members and the lack of any complaints on the forum from his clients (I don’t recall any) at least convinces me that it’s worth entrusting my Alfa to him for a chip.
Gotta admit, Marcin is an expert on Italian stuff :)
Back
Top
