    Ramki Alfaholicy
Chiptuning.
That’s something to ask in the well-known topic in the 159 section
In the well-known topic, there is more information about piston damage completely unrelated to the chip.
Exactly, there was one case in a car after a chip and it concerned a 2.0JTDm diesel engine, and such problems occurred even without a chip in those engines. Here a colleague asked about the 1.75TBi from the Julka QV, where I never heard of such problems. The 1.75TBi, whether in the 159 or in the Jule, sometimes has a problem with a failing turbine before 100k km, but that is independent of the chip (and I don’t even know if there was a case after a chip) - probably a result of people changing the oil every 35k km instead of every 10-12k.
And that darn little filter in the supply hose?
that aside, but maybe if you change the oil every 10k you won’t hurt the filter? in any case, prophylactically in the Jule I replaced the little filter after 2 years (odometer 12k), and in the 159 right after importing (50k).
that aside, but maybe if the oil is changed every 10k then the filter won’t suffer anything? [QUOT
That’ll blow up... from old age due to the heat
Possible, because the filter is plastic, although on the other hand, turbo failures in a TBI were often after 2-3 years, and at mileages like even 50-70k km, I’m not sure the filter would have aged, I think if the filter was the cause, it was that the old oil with grime clogged it, hence either lubrication of the turbo was too weak or the filter finally disintegrated and there was no filtration at all (+ filter fragments were flying to the turbo, which didn’t help either). From my TBI, after 5 years and 50k mileage I inspected the old oil filter before the turbo, it was intact. As for the degree of clogging it’s hard to say, especially since a flush was done before the repair.
Anyway I decided on a gearbox guard, I’m now replacing the filters and in the future I think I’ll replace them every 2 years in my TBI (about ~25k km) and in my wife’s Giulietta every 3 years (~20k km), to make a sensible balance between replacement frequency and mileage between changes with costs (always at least a hundred for the car for replacement, counting labor). Also with reasonably decent oil (certainly not Selenia Star PE), now it was Motul X-Clean 8100 5W40 C3, plus Archoil 9100 and I hope the engine/turbo will stay healthy always. Before replacing this filter I also planned to do a flush (I’m doing it now)
In any case, prophylactically in my Giulietta I changed the filter after 2 years (on 12k odometer), and in the 159 right after import (50k).
write in what condition they were in both cars because I’m curious? :) Oil change doesn’t have a big effect on that (unless someone really does textbook intervals), more wear and tear (high heat) and I have the impression that it mostly punishes thick oil + pressure after cold start in winter. I once checked out of curiosity my filter a few thousand since the change and the screen was already slightly cracked, and I think it was after winter season that it happened, if I recall correctly
OK. Gentlemen, now about this filter. Where is it and how do you clean it. Thanks.
the filter isn’t cleaned, it’s replaced. Here you have the part number and roughly the location from ePera for the 159 TBi (i.e., also for the Juliet QV):
http://www.forum.alfaholicy.org/159...przed_turbina_1_75tbi.html?highlight=filterek
In Giulietta 1.4 there is a different part number, it was somewhere, look for it
write in what condition they were in both cars because I’m curious? :) Oil change doesn’t have a big effect on that (unless someone really does textbook intervals), more wear and tear (high temp) and I have the impression that it mostly punishes thick oil + pressure after cold start in winter. I once checked out of curiosity my filter a few thousand since the change and the screen was already slightly cracked, and I think it was after winter season that it happened, if I recall correctly
In both cars the screen seemed intact (as much as one can see). Both engines were after a flush, the filters seemed darkened, but it was hard for me to tell if clogged or just dirty from old oil. To remove them I sawed off the hex nut at the end of the bolt, but the plastic seemed to have welded to the metal and I couldn’t pull it out – ended up ripping out pieces of the screen – didn’t learn much because the pieces were small.
And best of all is to remove the filter from the bolt and have peace of mind...
That’s what many do too, but I think that for something it was put there, so I’ll replace it fairly often
is provided for the break-in period so that the bearings on the crank don’t get damaged by the debris.
the gasket is provided for the period of engine bedding so that the bearings on the crankcase don’t get damaged.
do you propose in exchange to install a bolt like the one on the other end of the hose? In the Julka 1.4TB this other side has perhaps a slightly different hole diameter but is the same length. I don’t know how it is in the 1.75TBi, is it possible likewise?
I propose to use a good quality oil filter and an oil change every 10-15k. No screen can stop what the filter lets through. It is also important to clean the magnesium in the drain plug of the oil pan.
I understand you mean if someone replaced the factory plug with a magnetic plug? In pre-facelift the plug is just a regular bolt, could it be different in the new ones?
Chym I have a bolt with ferrings- and in it magnesium. Model from 2014 year
Probably a magnet if anything :) According to Epera the drain plug for 1.4 is the same regardless of year and it is a regular bolt with a hole in the middle. Either someone changed it for you or you confuse it with the transmission drain plug where there really is a magnet.
Back
Top
