Jeśli chcesz dodać swojej Alfie charakteru i jednocześnie zaznaczyć przynależność do naszej społeczności – to dobry moment, żeby je zamówić.
Td04? I wouldn’t go for it if we’re talking about a daily driver.
And what did he find as the culprit?Today the culprit hunting for this whole mess will take place. I’d prefer it not turn out that something came loose from the engine. I’ve had enough of good news.
If the powertrain is all right then bigger purchases are ahead of me anyway. Slowly putting everything together:
I’m thinking of VL38 turbo kit 55248311 + Intercooler 2.0JTD. When I’m slightly out of the financial hole, Cinsoft’s program. Primarily to lower the EGT.
Am I understanding/figuring things out correctly, or is there something else worth doing?
After what mileage? Were there any signs of wear? In mine I’ve got 207,000 km. After the chip. And nothing done so far. Maybe it would be worth doing a service after all. What does VL38 give. It’s bigger and costs twice as much. What should I check?
Yes, under load the rotor was losing balance and rubbing on the housing. Fortunately the turbocharger was the sole cause of the whole commotion.
The car currently has 160k km. The only sign of wear was a quiet rattling while operating the accelerator pedal (like screws in a can). While driving it’s practically inaudible - at idle more pronounced.
Since the turbo is anyway to be replaced in my case, I bought VL38, which has greater power gain potential. As it turns out, it won’t be necessary for the repair itself, but a new IC from FMIC / after consulting with the tuner I changed my mind about the diesel. Next month chip.
Grats collected, today IC, turbo and oil with filters arrived - time to act![]()
But you wrote that the turbo had no play.
Did anyone inspect the pistons with an endoscope? Because if metal chips were flying into the cylinder it’s not necessarily good for him, I hope not...
Plot? (Chart)208 horsepower 310 Nm
Sent from my SM-G950F using Tapatalka
