    Ramki Alfaholicy
[Giulietta] Chiptuning.
I also have 55248413 MA 150 HP, part number Garetta 811311-002; according to Garetta catalog it’s the same as 170 HP, and according to Fiat’s number also 170 HP.
I read somewhere about a tuning company from the Netherlands that the engine software can be changed; you can send them the ECU and they install new software and you can get 185–190 HP.
I don’t want to believe there’s a different exhaust camshaft, especially since Fiat in engines always gives a few more horsepower.
140 and 150 MA have smaller turbochargers and a different camshaft.
Please provide a source for these heresies.
The topic has been discussed before; I checked it well myself. Eper doesn’t lie.
On my turbine there is a Honeywell marking, as well as 1446, so.. For the uninformed Honeywell is simply Garrett.
In the attached photos, a picture of my turbine under the hood, and on the table from left TD04, 1446 and IHI. In the third photo a picture of the engine’s turbine in a showroom 1.4 MA 150. Thank you, regards.
Are you talking about me? ;) I have 1446 for sure, checked. Earlier they used IHI. Sprint 2k15. I didn’t chip it, but I talked to Cinek and Conmir and despite that they aren’t able to extract as much from 150 as from 170.. I don’t know why, they aren’t either.
about you :) meaning the opposite of what I remembered from your comment - you were at my place almost exactly 2 years ago, memory plays tricks :)
Exactly :) Earlier they mounted IHI and squeezed out 150 hp from them, but the housings cracked and they switched to 1446 just before my Sprint was produced, perhaps early 2015.
In the attached photos, a photo of my turbine under the hood, and on the table from left TD04, 1446 and IHI. In the third photo a photo of the turbine of a car in a showroom 1.4 MA 150. Thank you, regards.
And where in this photo is the 1446?
In MA there is also MGT12, even though according to EPer it should be 1446 :)
I also have 55248413 MA 150 HP, Garett number 811311-002; according to Garett catalog it’s the same as 170 HP, and according to Fiat’s number also 170 HP.
I read somewhere about a Dutch tuning company that the engine differs in software; you can send them the ECU and they install new software and you can get 185–190 HP.
I don’t want to believe there’s a different exhaust camshaft, especially since Fiat engines always give a few more horsepower.
The camshaft is different and it’s not only the exhaust lobe.
The camshaft is different and it’s not only the exhaust lobes.
If I have a Garett 1446 turbine in a 170 HP engine, what is the point of installing a different exhaust camshaft? These are the costs of the entire project; you’d have to modify the engine, whereas you can just modify the software and obtain 150 HP with ecological benefits at no cost.
That’s how Giulia was done, installing the same engines in the 280 HP and 200 HP early production versions.
Of course my colleague is aware that in MA there is ONLY an exhaust camshaft?
Facts, photos? Nothing?
Please also explain how it’s possible that with a different camshaft 170 and 150 have the same torque?
The intake camshaft exists, only the valve lift is regulated.
On a foreign forum it’s shown that up to 4.5k rpm everything is identical compared to 170. Only above that is there a restriction.
Sent from my URSUS C-360 3P
The guy obviously knows that in MA there is ONLY an exhaust cam?
I’d also like an explanation of how, with a different cam, 170 and 150 have the same torque?
It isn’t an exhaust cam, because the same cams are used to control MA, they also differ. The facts are that in Mito I have a very sharp cam and I tested both.
As for torque, the cam makes a difference in the high range. The same modification was used in the t-jet 120, which had different cams than the 150.
We are talking about probably the second generation of multiair. There can be differences between generations, inside they probably don’t. The T-jet works on an entirely different principle and there different cams make sense. It’s also odd that up to 4500 rpm 150 and 170 have identical parameters, characteristics, which implies the same volumetric efficiency; with other cams that would be unattainable.
Hello
Has anyone had any experience with giulietta 1.6jtdm after tuning? Is it possible to squeeze around 130 HP out of it?
Hi!
I have a Giulietta 2.0 150 with GTB15 turbo.
Currently planning FMIC + intake GSR.
Key question - will a turbo from the 170 version (gtb15) fit plug and play to this engine?
I’m aiming for around 210 horsepower, is that realistic?
Hi!
The turbo symbols are the same.
Cinsoft claims that in these versions 140/150 there were GTB14 and in 170/175 GTB15.
Is there anyone on the forum who has done this?
Ask Cinsoft :)
I think in the original post you meant to say you have a 2.0 with GTB14. Because if you already have GTB15 then yes - another GTB15 will fit.
Back
Top
