    Ramki Alfaholicy
Android Auto
AAWireless, 2021 model
The map may be on the right, small, and the music larger or full screen.
I haven't tested wired yet.
I see that skipping the 2019 model purchase was a perfect decision.
If the only criterion is a newer Infotainment, then indeed ;-)
Gentlemen, I read on some English forum a suspicion that Google updates to CW are linked to users connecting to different cars instead of always the same one. Some kind of update algorithm, supposedly.
Fact is, that in Stelvio I didn’t have it and today I connected to some Toyota and it appeared. Then I connected to Alfa - and it’s there as well...
Maybe it’s a coincidence or maybe true, hard to tell.
I only connect to one car and CW I already have. So probably not that
Just because you only have one car doesn’t mean it isn’t “that”. The distribution algorithm reportedly takes several conditions into account, what I wrote: the phone model, OS version... Of course this can all be nonsense and cases. If someone feels like trying with two cars, they can give it a go.
Mine was the same - I showed AA to a service client, during the trip home in the Alfa nothing new appeared yet, but the next morning CW popped in.
If someone is in a hurry to CW, just clear the Android Auto cache and Google Play Services. It worked for me, and I don’t have the latest AA version - I think 6.7.
clearing the Android Auto cache and Google Play Services is enough. It worked for me
I did it on my side in the latest version and it didn’t work. Some kind of lottery.
In the latest versions of AA, do Google Maps disappear for you?
They are on my side. The latest version from apk-mirror.
Maybe this will help someone. I connected a Motorola MA1 adapter to the Giulietta MY22. It works very well, 1:1 just like a wired connection. After starting the car it takes about 20-30 seconds and Android Auto loads in wireless mode.
Exactly I was wondering about that, thanks for the info - and how about battery drain?
My Android phones burned through the battery terribly - hence I had a cable plugged in for charging from a 3A charger in the cigarette lighter socket. It was OK when I just needed to get close, but trips like 1h there and 1h back would drain the battery by about half. Phones heated up during such use. I was using AAWireless, but probably no difference. On iPhone it’s much better, the phone doesn’t heat up and doesn’t drain noticeably, though when I go somewhere far I still use charging.
My Android phones burned through the battery terribly - hence I had a cable plugged in for charging from a 3A charger in the cigarette lighter socket. It was OK when I just had to drive close, but routes like 1h there and 1h back would drain the battery by about half. Phones heated up during such use. I used AAWireless, but probably no difference. On iPhone it’s much better, the phone doesn’t heat up and doesn’t drain noticeably, though when I go somewhere far I still use charging.
Probably depends on the phone. For me, Android Auto didn’t drain the battery, because it was connected via cable ;) and usually the USB port could manage to charge the phone during AA usage. With iPhone it also charges, but slower I feel (probably due to a much larger battery).
Sent from iPhone using Tapatalk
Maybe it will be useful to someone. I connected a Motorola MA1 adapter to the Giulietta MY22. It works very well, 1:1 same as a wired connection. After starting the car it takes about 20-30 seconds and Android Auto loads in wireless mode.
Exactly (in the sense of today) I bought such a Motorola - Giulia My21 - went without any problems (shock because with me such things always something...).
That was the only thing I lacked. It works well, 1:1 pass-through, I didn't notice any delays, took a short trip and nothing happened.
I'll also sort the double-sided tape with Velcro so it doesn't dangle.
I got home and wonder if Giulia cuts power to these USB ports, I never leave anything connected to them?
I'll find out in the morning....
Stelvio it probably does cut power Giulia also. And do these MA1 have no LED to let you know it’s off when the engine is off?
Yes, the USB wakes up as does the radio; if you open the doors or locks, but if you don’t turn the ignition it goes to sleep quickly, like a minute. This is good because the dongle and radio boot already. They also sleep within a minute after the radio turns off (i.e., not the radio but the screen, because the radio is still on standby for a while)
It has a diode, but I had to gather myself, and during a test drive I was in a hurry anyway, so I didn’t look, and then I thought, I’m not 100% sure.
Probably it cuts power, I once dug through a forum how it is and something is ringing (memory is good, just short).
Yes, USB wakes up as does the radio, when you open the door or locks,)
Then I can sleep easy. From what you write it’s true, such a pattern of 'sleep/wake' is good, because I didn’t test how long after night, on a new start this thing will "wake up",
I checked/installed and shortly after there was a drive.
Back
Top
