Fiatdiag, TS Diag, Alfadiag
cos nie widze twoich kodów ISO w tym zestawieniu.
Support airbag ECU list AlfaDiag 3.2.1.0
Ecus MY97, MY99
manufactured by Allied Signal, TRW and Breed.
A.R. 156 (STEP 3, 4 LOOP) 55-A7-86-83-97-1C
A.R. 156 (STEP 4, 4 LOOP) 55-A7-86-85-97-9E
A.R. 156 (STEP 4, 6 LOOP) 55-A7-86-04-97-9D
A.R. 156 (STEP 4, 6 LOOP) 55-A7-86-86-97-1F
Lancia Y (STEP 4, 4 LOOP)
Marea (STEP 4, 4 LOOP) 55-A7-86-07-98-A1
Lancia Y (STEP 4, 6 LOOP) 55-A7-86-08-98-A2
A.R. 156 (6 LOOP GSX, GDX, G DX E SX)
Lancia 839 (6 LOOP G DX E SX) 55-A7-86-89-98-23
A.R. 156 (3 LOOP) 55-A7-86-8A-98-A4
A.R. 156 (4 LOOP)
Lancia 839 (4 LOOP) 55-A7-86-0B-98-25
NUOVO DUCATO 298FP 132314908 55-26-86-04-98-9D
BRAVO/A 298F 46537777 55-26-86-85-98-9E
BRAVO 46768869 55-26-86-85-98-9E
MULTIPLA 898 F3 46513525 55-26-86-86-98-1F
MULTIPLA 898 F3S 46537989 55-26-86-07-98-20
BRAVO/A 798 46750553 55-26-86-8C-98-25
BRAVO 46768868 55-26-86-8C-98-25
BRAVO/A 898 FS 46541775 55-26-86-08-98-A1
MAREA 898 FSP 46538652 55-26-86-89-98-A2
BRAVO/A 798 F 46541774 55-26-86-8A-98-23
MAREA 6 loop 46770172 55-26-86-0D-19-A7
DUCATO 898 FP 132438808 55-26-86-8B-98-A4
LANCIA K: 55-AB-86-8A-98-A8
BERLINA, SW: 60661228 55-AB-86-8A-98-A8
COUPE’: 60661231 55-AB-86-8A-98-A8
LANCIA K COUPE’ 60661347 55-AB-86-89-98-A7
LANCIA K 55-AB-86-08-98-26
BERLINA, SW 60661230 55-AB-86-08-98-26
LANCIA K (4 loop, no ppd)
BERLINA, SW 60668931 55-AB-86-19-19-38
LANCIA K (4 loop, no ppd) COUPE’ 60668932 55-AB-86-1A-19-B9
LANCIA K (6 loop, no ppd) 55-AB-86-1C-19-3B
BERLINA, SW: 60667089 55-AB-86-1C-19-3B
COUPE’: 60667088 55-AB-86-1C-19-3B
FIAT BARCHETTA 46535843 55-AB-86-07-98-25
COUPE’ FIAT 46316266 55-AB-86-86-98-A4
COUPE’ FIAT 55-AB-86-91-98-2F
A.R. SPIDER/GTV 55-AB-86-80-80-
A.R. SPIDER/GTV 60659075 55-AB-86-85-98-23
A.R. SPIDER/GTV 55-AB-86-10-98-AE
PUNTO: 46517272 55-AB-86-04-97-A1
PALIO: 46529745 55-AB-86-04-97-A1
FIAT COUPE’ RICAMBI 55-AB-86-04-97-A1
A.R. 145/146 RICAMBI 55-AB-86-04-97-A1
FIAT 600 46552426 55-AB-86-01-97-9E
FIAT 600 46765423 55-AB-86-98-19-37
A.R. 936: 60626560 55-AB-86-02-97-1F
A.R. 936: 60662209 60651560 55-AB-86-83-97-21
A.R. 936 (4 loop, no ppd): 60668933 55-AB-86-9B-19-BA
A.R. 936 (6 loop, no ppd) 60667090 55-AB-86-9D-19-BC
FIAT Barchetta: 46476309 55-AB-86-0B-98-29
LANCIA K: Berlina, SW, Coupe’: 46517267 55-AB-86-0B-98-29
A.R. Spider/GTV: 60652259 55-AB-86-0B-98-29
A.R. 145/6 46746842 55-AB-86-8C-98-2A
A.R. 145 46538799 55-AB-86-0D-98-AB
A.R. 145 GDX 55-AB-86-0D-98-AB
A.R. 146 46548396 55-AB-86-0D-98-AB
A.R. 145/6 46538798 55-AB-86-0E-98-2C
Czyli jest jakas lipa w polaczeniu ????
Dodam ze kolega z alfadiagiem , rowniez mial problem z polaczeniem sie z poduszkami.
Z drugiej strony wizyta w serwisie , przyniosla skutek w postaci skasowania bledow poduszek z tym ze to na nie dlugo pomoglo.
A wiadomo ze w serwisie nie podadza Ci co wywoluje blad.
Z faktury z ASO mam taki kod iso A7 86 02 97 9B
Czyli niby pokazuje wlasciwy kod ISO
hmmm , zaczynaja sie zagadki ??????
Mozesz podac mi wlasciwe ustawienia bufora i czas latency ???
- ponizej ustawienia bufora, takie same jak dla alfadiaga.
Zrobilem reset parametrow adaptycyjnych i jest lepiej ale idealnie nie jest. Odpala fajnie, pracuje na lekkim ssaniu tak 1200-1300 obr ale jak dodam gwaltownie tak 2-3 razy gazu to dusi go. Na razie mozna ruszyc w miare ale do idealu brakuje. Przed resetem zeby wlaczyc sie do ruchu to byl wyczyn.
Stalo sie to dosc nagle tej jesieni, najpierw pracowal jakby nie na wszystkie gary po uruchomieniu na zimnym. Wymienilem swiece zaczal odpalac normalnie ale trudno bylo ruszyc, wiec diagnoza w aso - wymienic przeplywomierz. Wymienilem od razu nie pomoglo ale po resecie jest lepiej. Moze wtryski leja albo cos z przewodami?
W programie Bosh Esi Tronic jest taka rada na alfę jak ma problemy o poranku, aby osuszyć i sprawdzić szczelność tych kanalików na kable i świece.. bo często zbiera się tam wilgoć.... Może coś w tym kierunku trzeba by posprawdzać? Teoretycznie jesienią właśnie poranki są bardzo wilgotne.. U mnie też problem się pojawił jesienią.. ( pytanie tylko czemu na LPG jest OK a na PB takie dziadostwo?:) )
Parkuje w garazu - jak zmienialem swiece wszystko raczej wygladalo ok. Powiem szczerze ze od momentu kiedy ja kupilem (miala niecale 40 tys przebiegu - 3 latek) na zimnym nie bylo rewelacji zawsze lubila strzelic w tlumik jak sie dodalo kilka razy z rzedu gaz.
Dzieki Bubu321, raczej jednak jest to cos zwiazane z moim sterownikiem.
Podlaczylem sie z swoim sprzetem do auta kolegi , i nie bylo problemu z polaczeniem sie z poduszkami.
Jedynie co mnie jeszcze zastanawia to fakt , ze po podlaczeniu sie u kumpla ,nawiazalo lacznosc z sterownikiem , byla identyfikacja , ale nie chcial zczytac ewentualnych bledow.
Program robil to bardzo dlugo i zawieszal sie , lub zrywal lacznosc.
jest jakas moze inna wersja tego programu ????
KWP71
Aro mam dla Ciebie nowinkę.. może się ucieszysz a może nie (parę zł trzeba wyłożyć). Na 90% przyczyną porannej czkawki w byłł akumulator! 205zl wydałem właśnie na jakiś 60Ah i mam nadzieję, że już będzie jeden problem mniej:D
Po całonocnym ładowaniu akusa i dojechaniu do sklepu, okazało się, że te co na tam na półce stały miały większe napięcie (>12,6V) niż mój (12,2V).. jako ciekawostkę dodam, że akusa miałem 3-letnią Centrę Plus z Zielonym oczkiem ( czyli niby miał być OK).
jakbyś chciał więcej informacji jak sprawdzić aku to napisz. Ale na pewno przyda się jakiś miernik i prostownik:)
TAK, inna wersja to alfadiag w wersji 3.3.0.11
Dzieki bubu za pomoc , ale tak jak pisales mojego kodu iso nie ma w obslugiwanych ,i z polaczenia z poduchami lipa.
Podejrzewam ze panowie z aso cos przygrzebali egzaminerem przy ostatnim kasowaniu bledow ( chyba jest to mozliwe) i pozostaje mi tylko ASO hmmmm.
W przyszlym tygodniu sie do nich wybiore i dam znac jakie sa efekty wizyty.
pozdrawiam i jeszcze raz dzieki
Potwierdzam już na 100% winą porannego szarpania był wadliwy akumulator. O dziwo auto odpalało bez problemu.... dziwne ale prawdziwe:)
Wystarczy 8 godzin jak postoi i juz zamula - jak przejade 500m to juz lepiej, a jak wskazowka ruszy z 50st. to jezdzi ok. Kiedys bylo tak, ze jak byl zimny to jak na lekkim gazie na 2gim biegu jechalem (wtedy bylo najlepiej czuc) to przy mniej wiecej 2200 obr. tak jak by mi ktos reczny zaciagnal i jak doszlo do 2400 obr. to puszczalo jakbym nagle wcisnal pedal gazu. Teraz jak zimny to prycha i muli tak do 1800 bo jak wyjde ponad to jest lepiej.
Wyglada to tak jak ruszam ze wciskam gaz i auto nie chce jechac jak przekroczy 1800obr. dostaje kopa.
mam to samo, mechanik wymieniał mi połowe części w aucie i nie pomogło... teraz już szwankuje nawet jak sie nagrzeje, nagle zamula, później przestaje ...
dosyć ciekawa diagnoza.... Ostatnio walczyłem z kontrolką check engine i rzekomo uszkodzoną przepływką - podmieniłem u Rentgena przepływomierz jednak było bez zmian i błędu nie dało się skasować. Pokręciliśmy trochę przy samochodach a ja zapomniałem wyłączyć kluczyka ze stacyjki przez co akumulator się trochę rozładował (ostatkiem sił przekręcił mi rozrusznikiem) ale odpalił. Natomiast po południu wsiadłem do auta i kontrolka zgasła a auto zaczęło prawie normalnie jeździć - piszę prawie ponieważ czuć jeszcze czasami minimalne dziury w gazie... I teraz się zastanawiam czy to wszystko nie jest winą słabego akumulatora....
Alfa bez sprawnego akumulatora nie jeździ i koniec kropka:) szarpie, przerywa rusza jak ŻABA!! Ja normalnie jak rano odpalałem auto, to wpierw się rozglądałem czy nikogo nie ma w pobliżu bo się wstydziłem ruszać!! Jak ktoś był to czekałem z 30 sekund na luzie zanim zaczynałem jechać:)
Jest jeszcze jedna sprawa, pasek alternatora.... sam akumulator może być tylko jedna z przyczyn braku prądu... Mam w planie profilaktycznie zmienić pasek alternatora.. Napięcie łądowania niby jest 14,5V, ale już wolę zabezpieczyć się na zaś:)
ps. ostatnio spędziłem ze swoim akumulatorem, prostownikiem i miernikiem CAŁĄ NOC.. łądowałem, sprawdzałem co sie dzieje itp.. pojechałem do sklepu na dołądowanym i jeszcze ze dwa razy podglądałem napięcie... Powiem tylko tyle: było bardzo niestabilne i lubiło szybko opadać. Oczywiście miałem nockę w pracy i go wielokrotnie kontrolowałem ( obok mialem jeszcze drugie auto do wglądu:) ).
podrzuci ktoś interpretację błędu poniżej?
grzebałem ostatnio przy sondzie ale nie wiem czy to może być od tego
- przyklejony temat "opis bledów".
- to nie od sondy lambda, błąd wraca po wykasowaniu ?
- brak parametrów środowiskowych ,
- albo to nie błąd z alfadiaga albo kolega nie przewinął suwaka od bledów.
- z opisu jest to błąd czujnika położenia i obrotów wału korbowego, czujnik RPM silnika.
P0335 - Czujnik A położenia wału korbowego - usterka*
P0335 - Crankshaft Position Sensor A Circuit Malfunction*
no rzeczywiście zapomniałem o tym suwaku :/
a widziałem ten spis kodów błędów, ale nazwa angielska mi się nie zgadzała więc nie wiem czy te błędy pasują też do mojej alfy
narazie błąd się nie pojawił powtórnie. Czy jest taka możliwość, że ten błąd pojawił się w momencie kiedy samochód kilka razy pod rząd nie chciał odpalić (rozrusznik kręcił, a on nie chciał zaskoczyć)?
- błędy do numeru 1000 to błędy nie objete normą, tzw. błędy producenta, tutaj alfy.
- i są takie same , nie zależa od modelu.
- błąd ten mógł powstać z powodu tak jak piszesz.
- dlatego parametry środowiskowe powiedzą czy to błąd stały, chwilowy, okresowy.
narazie błąd nie powraca.
Czy jest taka możliwość, że czujnik położenia wału się zawiesza? Wymieniałem czujnik (fakt ze nie na nowy) i problem dalej się pojawia co jakiś czas - problem z odpaleniem. Coś wpływa na pracę tego czujnika?
