Fiatdiag, TS Diag, Alfadiag
Mam logi
Kod:
UseUSB: False
SerialPort: COM1 : VCP0
KwpTiming:
RequestInterByteTime: 5
EcuResponseTimeout: 1500
EcuResponseInterbyteTimeout: 100
IsoTiming:
EcuResponseTimeout: 2000
EcuResponseInterbyteTimeout: 150
Sending bytes: [ 55 AA 55 AA 55 AA 55 AA ]
Received bytes:[ 55 AA 55 AA 55 AA 55 AA ]
Expected Bytes: 1 Received Bytes: 1 Total wait time: 0 ms
Expected Bytes: 6 Received Bytes: 6 Total wait time: 0 ms
[ 7F 81 11 ]
Expected Bytes: 7 Received Bytes: 7 Total wait time: 0 ms
[ C3 00 32 02 6E 14 0A ]
[ 7F 83 12 ]
Expected Bytes: 12 Received Bytes: 12 Total wait time: 0 ms
[ 7F 83 10 ]
[ 7F 10 12 ]
[ 61 80 34 36 35 34 39 31 30 35 20 20 20 30 32 38 31 30 30 31 38 39 30 00 31 30 33 37 33 35 36 37 33 34 00 00 35 5A 39 33 32 25 FD 86 02 16 70 20 20 20 20 20 20 20 20 20 20 19 98 06 27 ]
Test Complete
kolejne logi:
Kod:
AlfaDiag.Ecus.Exceptions.EcuException: Failed executing ReadFaultCodes. ---> h: readStatusOfDiagnosticTroubleCodes failed.ResponseCode[ServiceNotSupported]
   w a4.a(Byte A_0, Byte A_1)
   w AlfaDiag.Ecus.Kwp.KwpEcu.d()ResponseCode[ServiceNotSupported]
   --- Koniec śladu stosu wyjątków wewnętrznych ---
Server stack trace:
   w System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs)
   w System.Runtime.Remoting.Messaging.StackBuilderSink.PrivateProcessMessage(RuntimeMethodHandle md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs)
   w System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
Exception rethrown at [0]:
   w System.Runtime.Remoting.Proxies.RealProxy.EndInvokeHelper(Message reqMsg, Boolean bProxyCase)
   w System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(Object NotUsed, MessageData& msgData)
   w cg.EndInvoke(IAsyncResult A_0)
   w b8.aa()
   w bt.a(a A_0)
Panowie mam niestety problem z podłączeniem się pod ecu. Chciałbym zasięgnąć waszej porady.. Mam gtv z Motroniciem 2.10.4 i AD w wersji 3.2. Kupiłem Vag Kkl obd2 i przejściówkę na pin3. W momencie łączenia się wyskakuje mi komunikat zebym sprawdzil czy kluczyk jest w poz MAR i sprawdził podłączenie, a zagłębiając sie dalej pisze coś takiego: "Failed to read ACK bytes from ecu." yhm.. na początku myślałem, że to przez to, że nie podłaczyłem czerwonego kabelka z przejściówki, ale dzisiaj zrobiłem przejściówkę z gniazda zapalniczki i niby wszystko powinno śmigać ale tak nie jest.. proszę o radę..
Korzystałem z tej przejściówki z OBD na 3-pin przy 164, jak łączyłem się przez KTS. Nie udało mi się również połaczyć. Wydaje mi się, że to z racji, że przejściówka po stronie OBD ma jedynie 5 pinów a nie komplet, więc komputer uznaje, że nie ma sterownika auta po drugiej stronie.
no niby tak, ale jest przecież grooo osób które przy pomocy tych dwóch kabelków bez problemu się łączyły z ecu.. kurcze zainwestowałem w te kabelki, miałem pewne nadzieje i teraz to miałoby się tak skończyć? może jednak jest na to rada?
@kuniu
- ECu to standardowe dla 1.8 TS, soft domyślny, czyli bez MOD-a.
- bład mówi o tym że nie ma połączenia z sondą lambda.
- dalsze zrzuty potwierdzają wynik diagnozy ECU: brak połączenia z sondą lambda.
- tylko czemu parametry adapatacyjne wygladają tak, jak by były przed chwilą wyzerowane.
- robiłem może zerowanie ECU a potem adaptację ECU ?
mozliwe ;) najpierw sprawdzilem wszystkie rzeczy pozniej robilem sensory...
co mam zrobic teraz? co z ta lambda?
i co znaczy bez moda?
- a czemu połączenie poprzez COM1, jesli to port wirtualny to COMx > 2
- z opisu stack wynika że ECU nie jest supportowane.
- nie może znależc odpowiednich serwisow.
- a czemu nie dałes pełnych logów ?, tak jak poniżej dla M1.5.5
[03/19/2010 1744] Testing: Bosch Motronic M1.5.5 Using Device: COM4 : VCP0 Version: 3.3.0.11
UseUSB: False
SerialPort: COM4 : VCP0
KwpTiming:
IsoTiming:
[ C1 EF 8F ]
[ C3 00 02 FE 00 50 00 ]
[ C3 02 32 02 32 14 0A ]
[ 50 81 ]
[ 61 80 34 36 37 33 39 34 33 36 20 20 20 30 32 36 31 32 30 34 39 34 38 20 00 31 30 33 37 33 35 39 36 35 31 20 02 04 39 33 32 5F 32 30 FE 86 83 97 73 00 00 00 00 00 00 00 00 00 00 19 99 01 08 ]
Test Complete
:51:
Dzisiaj zainstalowałem netframer 2.0 i dodatki, usunąłem stare sterowniki, zainstalowałem ponownie, i co najważniejsze zainstalowałem AD 3.3 w wersji demo. I jest postęp. Nareszcie AD zaczął się łączyć z ECU, ale jak to w wersji demo nie ma zbyt wiele opcji (temp i obroty). Co jakieś kilka minut niestety zrywa mi połączenie, a później dopiero loguje się za drugim razem. Czy jest możliwość sciągnięcia pełnej wersji z neta? Czy tylko demko? A może przerzucić się na unidiaga?
- o to chyba inne forum, ale google i poszukaj " instalacja XP bez napedu", chyba z pendriva.
- ale mam inne pytanie, który opis błędów dla ABS 5.3 jest poprawny ?
- może ktoś miał podobne blędy to sprawdzimy je z tymi opisami.
Witam, miałem kiedyś problem u siebie z ABS i po podłączeniu KWP71 u mnie był błąd
X=0x0A czyli według pierwszych interpretacji błędów dla ABS 5.3 (bo chyba taki mam) będzie Front RH speed sensor not feasible.
Tutaj kiedyś zamieściłem wynik:
http://www.forum.alfaholicy.org/156/12104-kwp71_interpertacja_wyniku_testu_abs.html
Dodam że błąd po pewnym czasie zniknął sam, więc nie wiem czy faktycznie była to wina tego czujnika.
Tak ciekawości może już ktoś miał okazję się przekonać czy opisując RH autor stał przed autem/maską czy siedział w aucie? :)
Analogicznie jak Front RH door, jeśli ktoś trzymał się standardu to "prawa ręka" kierowcy siedzącego za kierownicą :D
Co właściwie pokazuje funkcja "odometer" w alfadiagu?
- odometr pokazuje przetworzone impulsy drogi , co 400 metrów.
- impulsy są otrzymywane z ECU ABS, z lewego lub prawego czujnika Halla zamontowanego w lewym i prawym kole.
- ECU silnika nie ma czasu aby dośc dokłądnie policzyć metry na km i dlatego odometr pokazuje z dokladnością do +/- 10%.
- licznik przetwarza dokładnie te same impulsy ale posiada dodatkowy uprocesor który uśrednia droge z dokładnością do 200 metrów.
- impulsy, wartości binarne otrzymywane z gniazda OBD-II są podawane z dokładnościa do 200 metrów.
Dzięki za odpowiedź. Ostatnio spisałem sobie wartość licznika i odometer. Jest duża różnica między tymi wartościami więc podejrzewałem cofnięcie licznika. Wartość licznika to 155154 km, a odometer 237379,80 km. Pojeździłem jakiś czas i na liczniku przybyło około 600 km, a na odometer ponad 800 km. Dlaczego?
kolego post niżej masz napisane dlaczego tak się dzieje :sarcastic:
- poniewaz jesli ktos grzebał w liczniku, to on będzie fałszował przebieg.
- zwykle odometr pokazuje z niedomiarem faktyczny przebieg.
- czyli jesli odometr pokazał 800 km , to jest nabite 800 km + xx %.
Ale właśnie licznik prawidłowo nalicza kilometry (liczę z niego spalanie i wychodzi katalogowo) więc dlaczego odometer pokazuje aż o ponad 200 km więcej niż naliczył przez ten sam czas licznik (jakieś dwa tygodnie, licznik 600 km; odometer 800 pare km)??
Moim zdaniem to właśnie odometer źle mi nalicza.
