    Ramki Alfaholicy
Message - replace engine oil
T4co
New
Joined
Jan 28, 2026
Messages
9
Car
Giulia Intensa 25'
Hi all, I’ve been digging through forums but I can’t find a similar case. So the car Giulia 2.0 bought in October (from what I gathered produced in July 2025), had its oil changed in December after 1500 km. Now it has 3400 km on it (I drive about 2 times a week for about 30-40 km, sometimes once, but other times I’ll do around 100), and I get an engine oil change warning when starting. I went to an authorised service to ask if it’s possible that in December they didn’t reset the oil parameter (found in forums that this can happen too), but they told me at the authorized service at Zasady in Kraków that there is only one reset (I understand this is the main one for the inspection) and it has nothing to do with this and I should simply change the oil because it’s because I don’t drive much.
Has anyone here had a similar case? Did it really happen that less than half a year after an oil change and after barely 1900 km and infrequent driving but not on such short routes (though still urban) the oil had to be changed?
I found out that you can see whether the mechanic performed an oil reset, I said I don’t believe an oil change is necessary and I demanded on warranty that they check it, then they’ll take a look -.-
That’s why I went to them because they changed the oil in December, so they’re still responsible for that.
And that it’s an A.S.O is a joke, I already know how they wouldn’t replace the water lamps on warranty and they said it’s normal... honestly I’m not even sure they actually changed the oil there...
I didn’t have anything like that after an oil change at 5kkm. Tell them to immediately update the software (service action F538), because soon the inspection will chase you - it chased me 4 months before the due date ;)
So you bought new? From what I understood.
Generally if you plan to keep the car for a long time a VGate will be useful, i.e., connect to the car via OBD and you must bypass to get around the gate and do your own oil inspection. Basically to keep the GW you must drive to the A.S.O once a year, but in between if you want to take care of more frequent oil changes because it’s a new car you can do it yourself without issues, just with what I wrote. The equipment will also be handy in the future for many things. It’s clear they didn’t do a full inspection after the oil change, the computer with visible days and km is one thing and in the engine is another.
Hi all, I’ve been digging through forums but I can’t find a similar case. So the car Giulia 2.0 bought in October (from what I gathered produced in July 2025), had its oil changed in December after 1500 km. Now it has 3400 km on it (I drive about 2 times a week for about 30-40 km, sometimes once, but other times I’ll do around 100) and I get the engine oil change warning when starting. I went to an authorised service to ask if it’s possible that in December they didn’t reset the oil parameter (found in forums that this can happen too), but they told me at the authorised service at Zasady in Kraków that there is only one reset (I understand this is the main one for the inspection) and it has nothing to do with this and I should simply change the oil because it’s due to driving too little.
Has anyone here had a similar case? Did it really happen that in less than half a year after an oil change and after barely 1900 km and infrequent driving but again not on such short urban routes the oil had to be changed?
And did you do the inspection? because it implies that in July 2026 the inspection is due - a year passes and that’s why the car forces an oil change, mileage at that time has nothing to do with it (and an oil change after 1500 km does not reset the one-year interval)
Car bought in September. Oil change done in December. In the meantime I found out that Stellantis released a TSB (a bulletin nr 01-002-24) informing dealers that if a car has stood on a lot for a long time (I know it stood there, because when I picked it up there was GPS update in the app from July when it’s probably at the dealer) and it’s under a year since purchase and under 6437 km, the oil change light will come on then they should upload some software update or replace the oil (the whole warranty process is laid out there). Alfa Rome’s central office promised to intervene. We’ll see what they do, because service techs at Zasady don’t know about it. The snag is I did the oil change myself earlier and theoretically it shouldn’t have triggered an oil alert. I can assume either they didn’t really change the oil or simply didn’t reset it. Anyway, with the prices they charge for any service I expect professional work and not botched simple things, and I’ll have to waste a lot of time arguing with them about who is right...
They also didn’t reset the computer after an oil change when I did it between service intervals. Also the car counted days badly, so probably it thought a year had passed since the last change...
After the update of the F538 indicators, days are counted correctly. And the first oil change (before 3k km) does not reset the interval - because despite that change, the next one is still due at a 15k km mileage per the manual.
imho comparing with other brands, Alfa’s service isn’t expensive - yesterday I paid 250 PLN gross for brake fluid replacement. In total, the service for 30k km (with brake fluid replacement, cabin filter, air filter) came to about 1300 PLN gross (I had changed the oil earlier)
Back
Top
