    Ramki Alfaholicy
Chiptuning
Does anyone have personal experience with any box up to 200hp? I’d like to try it but the car is on lease so I don’t really want to flash a map.
I have a box but in a diesel with 180 hp
Also on lease
Sent from iPhone using Tapatalk
ESP is generally a problem for now, it can be disabled for the measurement time, but you have to pay a technician from the ASO for this service during the measurement. as for the start-stop system, it’s a ridiculously simple topic to disable in MM10JA once you have read the program, the fact that Swiftec doesn’t do it automatically is another matter ;)
View attachment 242706View attachment 242707
the car currently brakes only in 4x4 with a synchro, as soon as we figure out how to do a mode via OBD without changing the odometer, I’ll send what we managed to achieve
something crashed with screenshots so I’ll describe
- "S&S Enable flag" factory set to 1 (S&S system switch)
- "Upper threshold for S&S disabling"
- "Lower threshold for S&S disabling"
the first switch should disable the system completely, the next 2 are for "in case of"
In mine they fought with S&S for over a week and tried to disable it, but without success. They mentioned it’s some separate module, maybe they just didn’t know where to look. But if you manage to disable it, I’m the first :) I don’t know how it is in others, but I suspect it works the same - S&S should have conditions for it to operate, i.e. warm engine etc. and for me it’s like after 15 seconds from starting and stopping it immediately goes off and doesn’t care that conditions aren’t met.
A warm engine is not a prerequisite for blocking S&S. But there are other conditions, e.g. open hood, demand for high power from the climate control module. The easiest (home-made) way is to permanently disable S&S by bypassing the hood latch sensor at the right lock (passenger side) since this has the fewest side effects.
quilia q? do you have a readout from the ECU?
Klag3 where did you buy it and what are the impressions? I’m tempted to try.
I bought it from a Italian company dedicated to the 2.2 180hp
Julie came alive on D, incomparable to stock
Really worth it
Sent from iPhone via Tapatalk
klag3
i’m not a mechanic, so I don’t want to write nonsense, but recently I talked to some tuner who advised against the box, as it negatively affects the engine—especially the injectors,
how does this relate to your box?
it’s still on my mind too, but somehow - considering the warranty - I’m a bit wary..
thanks
klag3
thanks
I also talked to my mechanic, he didn’t mind
My box has 16 settings, I set it gently to 6, the effect is satisfactory
On Saturday I’ll turn it to max, see what happens
Before the inspection I’ll unplug the box, just a minute of work
The box is dedicated to the 2.2 180 hp
This isn’t a crap from Allegro
Since in Giulias the 2.2 engines 150hp, 180hp and 210hp are identical, only the software differs ……
After more research I settled on RaceChip or Novitec. RC is sold in Czestochowa and they sent two materials from Stelvio because they don’t have it for Giulia. Do you perhaps know if anyone distributes in WWA
facebook.com/MotoryzacyjnaPasja/posts/1317706048330665
youtube.com/watch?v=DEUeeIHWxbU
Or Novitec, but from what I see I’ll have to order it from Italy. And since I have little experience with this topic, service in PL and the possibility of return attract me. Novitec is however specialized..
And how about these racechips in petrols, did anyone test? In case of needing warranty, is it really undetectable after removal?
I finally got a RaceChip RS. According to the manufacturer, 13 HP difference, and at the price of a thousand (1300 to 2300) - it seemed okay as a test. Impressions are really good, although I’ve done only about 100 km.
Subjective differences because there was no dynamometer
- in all modes you feel more torque
- I don’t know why but in D mode it holds higher revs much longer - e.g., after acceleration
- systems respond frequently, and as with stock 200, the surface must be slightly oily for the ESP click to be audible on a straight line; now it’s standard once I floor it
Seems like well-spent pennies.
regarding the question about detection: I won’t help
Can you write provide photos of where it is plugged in?
My box has 16 settings I set gently to 6 the effect is satisfactory
On Saturday I will turn it to max to see what happens
just out of curiosity - how is driving at maximum settings?
I didn't have time to test the beauty in the service
Back
Top
