    Ramki Alfaholicy
Unsolvable electrical problem
Gorn
New
Joined
Jul 19, 2026
Messages
4
Car
Giulia Q
Good morning,
For almost 3 years I have been dealing with an electrical problem in a 2017 Giulietta. Quadrifoglio from 2017.
The problem is the appearance of an error tree on ECM2 (+ the power steering often disappears for about a second) in a situation of rapid acceleration in a low gear (1,2), mainly in RACE mode, but there were a few cases in D and N. The problem worsens with water (it happens up to a few days after washing the car / heavy rain) and vibrations, e.g. when pressuring the accelerator fully after crossing a speed bump. It has never happened at higher speed or during calm driving.
The errors that appear on ECM2:
P1D89-00 - EPS electric steering (NGE)
C1260-00 - ABS/ESC dynamic controls disabled
P1214-00 - Active exhaust valve 1
P1215-00 - Active exhaust valve 1
P035D-00 - Coil 6
P031D-00 - Coil 4
P035A-00 - Coil 5
The errors are random and appear in different combinations, usually several at once. The first two also appear simultaneously on ECM1, but that is probably because they appear on both controllers.
P035D-00 - Coil 6
P031D-00 - Coil 4
P035A-00 - Coil 5
The errors are random and appear in different combinations, usually several at once. The first two also appear simultaneously on ECM1, but I think it's because they appear on both computers.
In 2025 I visited a mechanic who didn’t do anything concrete, but as he stated: "moved the wires, so the problem may temporarily not appear, because the wires are routed differently". And indeed for over a year there was peace, but in recent months the situation occurred 3 times, so the problem exists.
In 2024 the car was at Italiano Garage twice for a longer time; the exhaust valve and the engine loom were replaced, but without effect.
My main suspicion falls on the electrical loom related to ECM2, its power supply, or ground.
Therefore 3 questions.
1. Has anyone encountered something like this, or has any suspicions?
2. Does anyone have a diagram of the location of the looms going to ECM2? Are there any places prone to wear, or where water can get in?
3. Does anyone know a mechanic (preferably in Silesia) who can diagnose something like this?
Study this thread: https://www.giuliaforums.com/threads/jerking-and-multiple-error-codes-on-giulia-quadrifoglio-–-need-help.66202/?tl=pl
Other errors occurred there but in very similar circumstances (rapid acceleration). It ended with a service action to stabilize the controller loom by adding a clip. Maybe this is a lead.
I’ve seen that thread, the symptoms are indeed similar, but the service action concerns the cable from ECM1, whereas in my case the errors appear on ECM2, so I don’t think that’s it.
Cheaper to probably buy the whole engine loom for 500 on Allegro and transfer it.
There is some way, the loom is quite cheap, but the transfer I suspect would be a nightmare and wouldn’t be possible without removing the engine.
On Giulia forums I also saw problems with the power steering caused by a worn cable going from the alternator to the starter, I’ll try to look into that:
image0-2-jpeg.147102
Does anyone have access to a diagram showing the routing of the engine and power steering loom?
1749822541323-jpeg.173240
I don’t have hard supporting materials but I have two questions.
Did the car have adventures?
Were all service campaigns on the car performed? (Best to take it to the dealer for this, online I couldn’t check). I have a 2024 car and there was a service campaign for a fraying loom. I don’t remember details, something about the tunnel layout, but that might be wishful thinking :-).
A standard topic regarding random errors is the battery, your problems don’t match the description, but it’s worth checking.
This is very decent material about the engine, but for you it may only be the cylinder numbering and information where the master ECU and slave ECU are
I looked at that area with an endoscope and found this:
So the problem will probably finally be solved...
The alternator cable worn into the housing of the steering rack, next to the power steering pump.
Back
Top
