    Ramki Alfaholicy
Rain sensor
Roman35
BANNED
Joined
Sep 28, 2014
Messages
652
Car
Giulietta 150 KM 2016
How is it for you, because it seems to me that something is not right with mine (unless that’s how it must be).
The sensor generally works, but after starting the engine, when it rains the wipers don’t want to start by themselves, only after turning them on manually once they then work fine, until the engine is turned off and then it’s the same again.
That’s why, for example in winter when they are frozen they wouldn’t work right away, which could be a reason for BMC failure, I had this but it was my fault because instead of defrosting the glass I sprayed fluid on the active wipers which sometimes had to come off the glass :P I always had little time... :P
The sensor generally works, but after starting the engine when it rains the wipers don’t want to start by themselves, only after turning them on manually once they then work fine, until the engine is switched off and then the same again.
The rear is the same - won’t start until you start the front. At first I also thought something was broken :).
Yeah, normal in this car, but I freaked out after switching from Hyundai where they worked in full automatic...
N
What? You won’t start the rear with one swipe without turning on some mode in the front? Do I understand it correctly?
The dumbest solution ever. :D Is such a setup used in any other car?
Well, yeah, but why implement such a lockdown? :D And if you spray the back and want to give it a quick wipe to fix it, does it allow it or not?
I drive a Brera? Wait, Berlin and Tourer? He says Berliną and Tourer- I translate: I drive a Berlina and a Tourer - I even got used to it, sometimes I just turn on the rear window heating in Alfa, but in a Citroën I can't imagine such a solution from the Giulietta. :D
Back
Top
