    Ramki Alfaholicy
Oil level sensor
talar44
Member
Joined
Nov 28, 2007
Messages
87
Car
Była AR 146 TI, AR 147 1.6 TS,AR GT 2.0JTS, jest AR Giulia Q4 2.0
Hello,
has any of you had a problem with the oil level sensor in the 2.0 MAT?
I'm asking because already the second sensor in the span of 10k km has failed on me (it stays perfectly halfway and surely is at 80% oil level)
When I add oil there is no reaction at all, still perfectly in the middle, I tried refreshing according to the instructions on the display and reset via the battery and nothing helped (unless there is some other way to reset or verify the cause, I’ll say right away that the ECU shows nothing, no errors)
And that’s why my question is whether any of you also have problems with this sensor and what it might be due to?
Thanks in advance and cheers.
What does MES show about this level, is it also crap?
I’m not talking about an error, just about the level.
Exactly, there is no parameter for the oil level, or I don’t know where to look,
it shows oil degradation level, the replacement interval, etc., but I didn’t find the level
If you have vgata via Bluetooth then install the MyGiulia app and check the oil level in mm. If wired then look in MES because it exists. The sensor for indicating between the gauges lives a bit of its own life. Here I wrote how to move it. But anyway the level in mm is the most reliable.
Everything is fine now, I did a reset as after an oil change and everything returned to normal (I even had a problem with my MES somehow the license expired but now it works), I scanned the whole system and a few errors on the bus came up, I’ll analyze later.
Thanks for the tips
cheers.
Back
Top
