    Ramki Alfaholicy
[Giulia] Map update page.
Status
Not open for further replies.
Notes:
- format the USB flash drive to NTFS*
- copy into the main directory a single unzipped map file and next to it the license file, nothing else.
That is, do not place any zip files or any additional directories on the media.
- the map update takes about 40 minutes and must be performed with the engine running. Shutting off the engine will interrupt the update and you will have to start over (so you should disable start/stop before starting the procedure).
@epsonix based on experience, it is recommended to use exFAT, especially when formatting the media on an OS/Linux system.
Official Mopar guidance indicates using NTFS, although apparently in some documents they changed their mind.
WARNING:
Remember that the date in the car multimedia system must be newer than the emission date written in the map file. Otherwise, more often than not the update does not initialize.
Status
Back
Top
