PPIotrek
New
- Joined
- Nov 16, 2016
- Messages
- 21
- Car
- ALFA ROMEO MiTo 1.4 Distinctive, 78KM, rocznik 2010
Dear Forum Members,
I, for my part, noticed in my own case mito such a kind of problem: the fan runs sometimes and not others - which means that the AC sometimes works, and other times you can die from stuffiness..
There are no rules with the fan: i.e. it can turn on immediately after a stop, sometimes after a few minutes of driving, other times after 30-40 km of continuous driving. It also stops working at different times - it happens that I drive to work 20-some km and it works the whole way, and other times it turns off after a few km.
Of course I diagnose whether it works or not via the climate control - either nice cold (really very cold air) comes out or not.
I went for the first diagnosis - the wizard ruled that the O-ring of the air conditioning sensor was shot and the sensor itself as well - swapped. It was good for 2 days. Then d...
In the meantime my alternator cracked (literally - the housing cracked). After replacing it with a new one the wizard ruled that the fan runs continuously and the problems should go away. They did not...
As I wrote above: sometimes like this, sometimes like that.
And now my question to you - have you had similar problems? What failed: the control, the module, the fan itself. I once had a similar issue in a Ford and there the fan went on its own: I replaced it, what exactly new but the replacement and for 7 years zero problems.
In this case mito I feel like repeating that action. Replace the fan, and only if that doesn’t help then look further... Especially since the fan mito is 8 years old, and the fan in the Ford was 3 years old.
