    Ramki Alfaholicy
Check engine light
Joined
Sep 16, 2017
Messages
10
Car
Gulia Business 200KM
Hello,
today during driving the check engine light came on. The car has just under 2000 km on the odometer. The problem went away the same day after driving a few dozen kilometers and restarting the engine. With the light on, the car was noticeably less dynamic, as if the turbo wasn’t working. Has anyone had a similar problem?
A moody Italian :) You have to get used to it :). Seriously though, you should read the errors at the authorized service (ASO) and fix the fault. Probably it’s software, because mechanically I haven’t heard of anything breaking yet :)
Next week I will be at the ASO to have it checked. I noticed one more strange thing: after starting a cold engine, sometimes it revs up to 1500 rpm and holds it, only after moving and stopping again do the revs drop to the working 900. Once I got an alarm error after starting the car and the message alarm unavailable after restarting, the error disappeared. I’ll let you know what they found at the ASO after the visit.
Mine also had a check engine today, it went away after a few kilometers. Coupled with the error light for the start/stop system (this system failure suits me just fine ;) and DNA mode permanently set to A.
I pulled into Carserwis quickly - the car generated a ton of battery errors and one active something like 'ECU capacity overflow' (I didn’t see it exactly).
Dark - didn’t you connect a camera/recorder to the installation? Because then the battery generates a lot of errors (e.g., with the airbags) and it’s possible that due to continuous use of the battery (park mode, etc.) the error cache overflows and the check engine is thrown (because the ECU gets clogged) - this is my theory, not Carserwis’ (because unfortunately at CS they simply cleared the errors, and there were about 3 on the A4’s side)
I was at Carserwis today as well; they stated that turning on the engine light was caused by a fuel pressure sensor fault, the fix is to install new software. This should also fix the issue of elevated revs when starting a cold engine. I have an appointment for this service next week, I’ll tell how the car behaves with the new software. I also had trouble with the vents; in none of the settings did the two circular vents on both sides work, but today they fixed it. I never connected a camera recorder or any other device that continuously draws power.
I had 3 times a check engine on Shell V-Power Nitro 100. One tank and only then. On 95 I didn’t have such adventures.
Sent from my iPhone using Tapatalk Pro
I had it on Vervie, now on 95 the warning light doesn’t come on either. Only, after starting a cold engine the revs rise to 1500 and fluctuate a bit; after shifting the gearbox to D everything is okay. When the engine warms up a bit, after shifting to Park it’s also fine, working at 900 rpm. Flashing the software is supposed to fix the problem, but I’m a bit afraid it might worsen performance.
darkkn1ghtIn September I had the latest (supposed) software for the engine installed at the ASO. Before the update, the car occasionally shuddered excessively after a cold start (I’m not the first person to complain about this). The September update eliminated this problem, but it caused the revs to surge as you described. Performances are probably unchanged. Everything seems fine in this matter. I fill with regular Pb95. If nothing new has come out since September, I doubt the surging will stop for you after this update, but of course I wish you the best and if there are changes, let me know. I’d happily check what version of this software I have, but I don’t know how. I have an ELM 327 connector, but in Torque Pro I don’t see a field showing the ECU software version.
The check engine light has never come on for me since new. I’ve driven over 4k km so far. Overall I’m very happy with this car.
I was at Carserwis to install the new engine control software (the latest available version). Generally I didn’t notice any major changes after this update. Right after starting the engine, revs stay around 1450, after about 3 minutes they drop to the working 900. You can also feel slight vibrations, shuddering, but it’s always been like that. Regarding revs in the service, they say that’s normal and that these engines rev like that. Do you also have such high revs after a cold start in the Park position?
I was at Carserwis to flash the engine control software (the latest available version). In general I didn’t notice any major changes after this update. Right after starting the engine the revs stay at about 1450, after about 3 minutes they drop to the working 900. There are also slight vibrations, shuddering, but it’s been like that from the start. Regarding the revs, at the service they say it’s normal and that these engines run like that. Do you also have such high revs after a cold start with the gearbox in P?
This is standard engine behavior at lower temperatures; it warms up faster so it doesn’t idle hard when cold, but 3 minutes? Depending on the temperature, for me it lasts from a few seconds to a max of 30 seconds.
I measured it with a stopwatch exactly, 2.35; outside temperature 12 degrees; it seems something isn’t right, besides that revs at 1450 are a bit too high. I’m curious how it will look in winter at subzero temperatures.
I can only say that I, too, was bothered by the slight engine vibrations at idle, but after asking at a service in Wrocław I also heard that it’s a matter of over-tight emission standards and fuel economy. So, this model is like that.
At idle they give a smaller amount of fuel and the engine runs at low revs; in the Passat B8 when people complained they sometimes increased the fuel amount at idle in the computer.
Ok, and what revs do you have after a cold start when the gearbox is in P position?
Normal, 900–1000, except I took the car in September and I haven’t been to an inspection yet, so I don’t have the new software.
I had 3 check engine lights on Shell V-Power Nitro 100. One tank and only then. On 95 I didn’t have such issues.
Digging up an old topic, I also got a CEL after fueling with VPower Racing 100 to full, but the error didn’t appear immediately after fueling, but after driving around 500 km and in the meantime I topped up to 98 because Shell wasn’t in reach.
After turning off the engine/car for the night and in the morning when I turned the ignition on the CEL and DNA were unavailable.
Car after remap, before remap I always fueled with 100 to full too and there were no problems.
Has anyone done any broader research??
Check what errors you have, then we can say something. For now it could be a random fuel issue. Switch off the ignition a few times and the check might disappear. But it’s worth checking what happened. I doubt it’s a fuel issue..
The error I had was U0415 P0401. The check didn’t disappear after maybe 3-4 times turning off and on. Only a guy who connected via OBD cleared it and there was a long list of faults. I couldn’t clear it with Torque, although the fault showed up. I don’t have MES.
I drove for about 2 weeks after the remap and there were no problems, I was pulling full throttle about 100 times, but later I added an air filter less restrictive Sprint, so more air came in, perhaps something with the mixture got affected; I read that the lambda sensor might have lit up, but it’s possible to guess what happened; soon refueling is coming, so I’ll see if this was a one-time action or if it will repeat
Five consecutive engine starts/stops should clear the check engine light on the dash. Unless the error pops up again when you start it.
Back
Top
