    Ramki Alfaholicy
Battery
arturo132
Member
Joined
Jun 3, 2011
Messages
466
Location
Opole
Car
Stelvio 2.0 280+, Giulietta 1,6
Hello
I am the owner of a Stelvio 2.0 for two weeks.
The car is new although from 2017, production July.
Since purchase I have been dealing with an battery problem.
The first thing I suspected was that the start-stop didn’t work.
Three days after purchase I try to start the engine and here are all possible errors and the engine won’t start.
I put in an old battery and drove for three days.
I arranged at the service for a replacement (inspection) of the battery.
I left the battery.
After two hours they call, that the machine for checking batteries confirms that the battery is OK.
They installed the battery, I drove 5 days and today I pull into the garage, switch off the engine and the history starts again i.e. a tree on the dashboard after attempting to start the engine.
Put in the old battery again and the car runs normally.
In my opinion it is a battery short.
What to do?
Call the hotline and tell them about the problem and specify which workshop. Maybe it’s worth starting from the warranty, we have assistance in the package. Let them come and diagnose the battery failure on the spot.
And on this old one you put in, did you drive three days because it died or because you ended up at the service?
Not the old battery works well.
The problem is with the new one.
I suspect it got a beating while the car was at the showroom.
I know this. The car is at the showroom, everyone looks at it (if yours was at the showroom and not on the lot), every opening of the door wakes up the system, often together with the fuel pump. And so several times a day plus the trunk lighting, starting the radio etc. And after a year the car leaves and the first report concerns the battery.
Tow truck and to the service. Don’t try anything and don’t replace the battery, just reset the computers and the service won’t see anything ;)
Sent from iPhone using Tapatalk
Disconnecting the battery (so some people call it a reset) does not erase errors from the system. And on the other hand voltage drops generate many other errors, seemingly unrelated to the battery. But of course the guy should benefit from the warranty and assistance. Nothing drives the service better than time with courtesy cars at the expense of the guarantor.
A car on a tow truck is a joy to the neighbors.
I’ll see what the service says tomorrow.
.... But of course the colleague should take advantage of the benefits of the warranty and assistance. ....
Not quite. It would be the case if in the official service centers (ASO) there were experienced, competent, 100% honest and motivated technicians.
In real life every visit to a workshop (ASO or not ASO) is a risk that the repair will be effective, but only temporarily - and in the meantime another ten things will break (as the customer learns after months or years). Not to mention part swapping (often small parts - relays etc, but not only - e.g. if there is no new part in stock and someone comes for a paid service).
I could write a lot here, but to summarize - by minimizing the number of visits to workshops I have kept my cars in excellent technical condition for many years :cool: And if you have to go to the official service - keep an eye on the mechanics non-stop.
In this particular case - if for some battery the car works correctly, then spare the other battery - it may be much cheaper than fixing the car after a "repair" in the official service.
In this particular case - if on one of the car batteries the car runs correctly, then treat the other battery as a spare - it can be much cheaper than sorting out the car after a "repair" at the authorized service center (A.S.O.).[/QUOTE]
Yes I considered that because a new battery is only 500 PLN. For now, after consulting with the service, I’m running on the second battery. If nothing comes of it, they’ll try to replace it with a new one.
In this particular case - if on one of the batteries the car runs correctly, then treat the other battery as a spare - it can be much cheaper than sorting out the car after a "repair" at the authorized service.
And what else should I spare? I don’t know what kind of service centers you’ve dealt with but to me this is incomprehensible. I even "supervise" another-brand service and I wouldn’t even think of doing such things. Although I know that since there are thieves who break into apartments there are thieves in other places in our lives too. But I wouldn’t decide to push the matter so that I don’t return to a vaguely defined service "because they’ll rob you". And as I see further, the service claimed it could be the battery and promises a replacement, so there’s nothing to complain about, maybe except that it takes a bit longer.
And what else should I spare? I don’t know what kind of service centers you’ve dealt with but to me this is incomprehensible. I even "supervise" another-brand service and I wouldn’t even think of doing such things. Although I know that since there are thieves who break into apartments there are thieves in other places in our lives too. But I wouldn’t decide to push the matter so that I don’t return to a vaguely defined service "because they’ll rob you". ...
Unfortunately - years of using and workshops. Want an example? Here you go - a showroom car, 3 years of service at the authorized dealer, on every account the cabin filter replaced. The next year I decided to replace it myself, I remove the filter cover - and there it is - empty. EMPTY. Meanwhile, once I go to an authorized service (another brand) with a warranty issue - diagnostics, a relay or something - too slow to engage... No problem - borrowed from another car in the workshop - I optimistically assume that the other one got a new one, but I don’t want to believe it. These are the least drastic examples... My own statistics of workshop visits - about 2/3 to 3/4 visits result in MINUS for the service. Maybe I’m unlucky.
I have no reason not to trust, it’s just that here we have a different approach (and practically no claims regarding labor). Of course, borrowing from another car is possible but it’s our demo or from the showroom. Sometimes there is no other option to check. But it’s always formally arranged later, even if only because a customer using an online account can view the service history, including that from previous owners in the case of a second-hand car (yes, such things are possible). But all such swaps are with my approval and I’m responsible for their legalization. Therefore, as I told the President, all our employees drive other brands to avoid suspicions about the origin of consumable parts. And returning to the topic, you’re just unlucky.
I’ll just add that the cabin filter is a troublesome filter. Looking at my Giulietta. In general, if I want it done properly... I do it myself. One dealer couldn’t fit the tunnel cover, another put the filter... so battered that half the air was flowing to the side. Why? Because they don’t feel like it, in my opinion it’s classic worker laziness. And of course I didn’t return to the complaint, so the dealer is happy that the customer isn’t whining. And when I looked in a neighboring thread at the procedure for replacing the cabin filter in a Giulietta... I can already see how they’ll replace it and maybe even carefully. :) No breaking of plastics and shoving the filter in blindly. Yeah right. :) I basically share ciafok’s view that every visit to a dealer is a risk that they’ll break something. Unfortunately sometimes it’s hard to avoid. :(
on alfaowner there are threads from some time ago about dead batteries in new cars, they replaced people’s under warranty and problem solved. find the thread, read it, and ask about replacement from the dealer
... I basically share ciafok’s stance that every visit to a dealer is a risk that they’ll break something. Unfortunately sometimes it’s hard to avoid. :(
This is also a topic, by the way... How many times have I felt like hurting the designers of modern cars just by starting to service my own cars ;) Everything is so complicated on purpose to hinder - or at least to maximize the difficulty - of any service task. And after replacing the cabin filter in Stelvio..., I already miss replacing that filter in the Mondeo MK4 - there you just have to remove the gas pedal - et voila :cool:
Stelvio - problem with the battery
Hello,
In my Stelvio 2.0 280HP (production end of 2017, but I bought it off the year-end sale in May 2018, the car sat in the showroom for a few months) has had the battery discharge twice in the last 2 weeks, the starter doesn’t turn at all. It’s winter now, but not that cold, it hasn’t dropped below -5 here by the coast. The car is garaged in a warm place. Sure I do short city trips, but I did identical trips with previous diesels without issues, certainly not in the first year of use! The first time I called assistance, the car started (with jumper cables), but after turning off it wouldn’t start again, we started again, lots of errors appeared, but I managed to reach the service, they checked and said the battery is fine, there was a loosened cable clamp on the battery (??). The car worked fine until yesterday. I washed it at a touchless car wash, got in and click - also probably related to moisture? Assistance again, this time on a tow truck because I was afraid to drive with all those errors. To another service. And again the same story, the battery is fine, clamps dirty. I’ll go pick it up now. Ok, but in 3 weeks I’m going to Italy, if it happens on the way there it would be a disaster, and in the mountains it can get -20 (my old diesel XC60 barely started a year ago). I hope the failure repeats before I leave and then they’ll replace the battery or something. Dear forum users - has anyone had a similar battery problem? By the way I turn off start/stop immediately after starting the engine. And the car has only about 11k km.
My car sits outside sometimes for a week. After starting the seats and steering wheel are always heated to the max. Start/Stop engages at 1-2 bars always. No problems. Let them replace the battery, something is wrong. Dirty clamps in the trunk?!
Hello,
In my Stelvio 2.0 280 HP (production end 2017, but I bought it from a year-end clearance in May 2018, the car had been on display at the showroom for a few months) in the last 2 weeks it happened twice that the battery discharged, the starter motor just wouldn’t turn at all.
Obviously - it’s winter now, but not that cold, here by the sea it didn’t drop below -5. Besides, the car is parked in a warm garage. I do short city trips, but I’ve done identical trips with previous cars (including diesels) and there were no problems, certainly not in the first year of ownership!
The first time I called assistance, the car started (with cables), but after switching off it wouldn’t start again, we started it again, lots of errors appeared, but I somehow got to the service, they tinkered and stated that the battery is fine, that a cable terminal on the battery was loose (??). The car ran fine until yesterday. I washed it at a touchless car wash, get in and clunk - maybe related to humidity? Assistance again, this time on a tow truck because I was afraid to drive with all those errors. To another service. And again similar talk, battery is fine, terminals dirty. I’m about to go pick it up.
Okay, but damn, in 3 weeks I’m going to Italy, if something happens on the route it’s a disaster, and in the mountains it can be as cold as -20 (my old diesel XC60 barely started a year ago). I’m hoping the fault repeats before I set off and then they’ll replace the battery or something.
Dear forum members - has anyone had a similar battery problem? Oh, I’ll add that start/stop is turned off immediately after starting the engine. And the car has only about 11k km on it.
Best regards
There was some thread on the forum where someone’s lamp was replaced because a short was causing the battery to discharge... I think a thread about start-stop I don’t have time to search for you..
Sent from my SM-N950F using Tapatalka
Back
Top
