    Ramki Alfaholicy
Wiper blade problem FL
Alfettone
Nowy
166 2.4 Mjet 2005
Hi guys, I have a problem with the lavafair mechanism ..... if I press the lever to wipe the windshield, it works perfectly except the washing of headlights, does not go out of the cleaning mechanism.
Of course the water pan is full and the dangling lights lit. What can it be? A fuse or something else?
Thanks for the help
The fuse nr.16 from 20A was skipped ..... I replaced it and now the wiper operates but the water does not come out !!
Hi.
Try to take a look at pump connectors
I have had a similar problem. The reason - poor electric connection.
Under the right mudguard is placed pan with two pumps. One for windshield (possible to get access from front of the car) and the second one for washing of headlights (access only from the side - under the mudguard)
Try to clean the connector or swich them. If swaped works washing of headlights and washing windshield does not then problem will be the pump - not any fuse or wire.
