    Ramki Alfaholicy
Worn-out ignition switch
Aroniaa
New
Joined
Dec 7, 2011
Messages
461
Location
Olkusz
Car
AR 166 3.0v6 azurro nuvola
Hello..
I wanted to present to you a problem that occurs over time in every car.. namely a sticking ignition switch or broken springs in the cylinder..
It would seem the only solution is to buy a new ignition switch and carry 2 keys with you..
or replacing the cylinders together with the ignition switch...
these are certainly good solutions but costly..
these costs can be reduced almost to a minimum
you need, by the method of transplantation, to relocate the Bembenek which is located in the car’s glovebox.. and in probably every car there is a lockable key compartment
it is in 99% like new because who locks the lock in the glovebox
Bembenek can be transferred obviously both to the ignition switch and to the door handle in the doors which also tend to jam/wear out...
Bembenek can be transferred by yourself but it requires clockmaker’s precision..
if someone feels up to it...
the cost of the transfer at the clockmaker depends on his own whim
I paid 30 PLN the ignition switch works like new.. alfa it has a lockable key compartment
Bembenek can be transferred, of course, both to the ignition switch and to the door handle in the doors which also like to stick/wear out...
Bembenek can be transferred by yourself but it requires clockmaker precision..
Back
Top
