    Ramki Alfaholicy
Winter scrapes
M
MITOholik
Guest
Hello.
Parking under the open sky MiTo under the open sky, в Polish text? Wait. I must translate properly.
Honestly I never had this problem, because the de-icer does its job perfectly - in my opinion it's not a very thick layer of ice at all, because as I mentioned a spray of de-icer and waiting a few dozen seconds solves the problem - at least so far it has.
Maybe the cover for the front and side windows will save the situation? It also protects the mirrors.
In a 155 it overlaps almost onto the middle pillar. Various sizes are available for purchase.
And what do you think about lubricating the door seals? Then there is no risk of the glass freezing.
There is also the option of playing with the remote. After unlocking the central lock, try to tilt the windows with the remote. I wouldn't worry about the actuator, it has overcurrent protection—if it’s too hard it shuts off. The glass passes under the gutter if you gently bend it. Mostly a de-icer plus lubricating the seals solves the problem.
There is also the option of playing with the remote. After unlocking the central lock, try to tilt the windows with the remote. I wouldn't worry about the actuator, it has overcurrent protection—if it’s too hard it shuts off. The glass passes under the trough if you gently bend it. Mostly a de-icer plus lubricating the seals solves the issue.
That's exactly the strategy I adopted last season. Five-seven, which cover are you referring to?? can you post a photo or a link? I park under the open sky by the blocks and I’d like that cover to still be there when I wake up in the morning. ;]
Today I bought a wax stick for lubricating the seals. Very handy, easy to use. Brand: Sonax. It cost about 20 PLN at Castorama.
Five-seven, which cover are you talking about?? can you post a photo or a link? I park under the open sky by the blocks and I’d like that cover to still be there when I wake up in the morning. ;]
I think it’s the upper plastic profile into which the glass slides.
Back
Top
