    Ramki Alfaholicy
Trunk lighting
mrlaku
New
Joined
Nov 20, 2014
Messages
47
Location
Car
Giulietta 1,4 170kM
Hello!
The trunk light has stopped working, of course replacing the bulb doesn’t help. It isn’t the fuse either, because I checked that the interior lighting on the same circuit works.
Has anyone possibly dealt with this problem?
Regards
Of course, a commonly known problem. The wiper, trunk lighting, and the latch of the hatch and problems related to them are the result of a worn electrical harness at the connection between the hatch and the fixed part of the body. You need to remove the rubber cover and find the frayed wire to reconnect it. I had a problem with the trunk lighting and the hatch latch, and it was caused by that unfortunate harness.
Regards.
I’ll be patching the left harness in the coming days - the trunk lighting and the left reverse light failed. I’m afraid that if I touch it, everything will come apart and I’ll have to solder each wire one by one.
But the trunk lighting isn’t in the hatch, but in the trunk itself, and I don’t see a connection with the harnesses. Unless I’m misunderstanding something
but it seems that the door opening sensor is in the hatch (it may be linked to the lock) and not in the body, so the sensor wires will be in the hatch.
Question: does it then show on the gauges that the hatch is open - if so then the problem lies elsewhere than in the hatch harness.
In my case it initially manifested as when opening/closing the trunk hatch the light went out or turned on halfway through the opening. Later it died completely. But the display shows a message about an open hatch only when it is actually open.
I’ll refresh this gently. From which side is the lighting cable run? In the left or right harness?
Has the side been determined? For me it’s a fresh topic.
In my case it initially manifested as when opening/closing the trunk lid the light went out or turned on halfway through opening. Later it died completely. But the display shows a message about an open hatch only when it is actually open.
Because it’s the other way around. Normally opening the hatch completes the circuit and turns the bulb on, and closing the hatch interrupts it. If the wire is damaged, the car thinks the hatch is closed all the time. The message of an open hatch is from another wire. The one responsible for latching the lock. I’ve dealt with this. There was a message, the lock wouldn’t latch, but the lighting was functioning correctly. And now, on the other hand, I have this lighting wire broken, but no message about an open trunk and the lock works.
Only the indicator, the triangle with an exclamation mark, lights up. Other faults/overall fault, or something like that. Not always, but usually. Could it be from this? Sometimes the trunk lighting comes on. Maybe the indicator signals a short? No other symptoms, all bulbs are in good condition.
If there is voltage at the power input of the lamp and the bulb does not light, then the rear hatch lock needs replacing. It has two sensors or however it’s professionally called, and one for the lighting is damaged—that’s the symptom. I’m dealing with something like that right now.
Back
Top
