    Ramki Alfaholicy
Startup errors
zielun
New
Joined
Oct 3, 2018
Messages
34
Car
Giulietta 2,0 jtd, Peugeot 308SW
I have the following problem. For some time after starting the car, errors pop up:
1. Check engine,
2. Inspect the engine transmission,
3. Start-stop unavailable.
Since the battery wasn’t brand-new, I thought it might be the cause. After replacing the battery with a new one, the errors still appear.
Do you know what the problem might be? 2.0 etc 175 HP TCT
Giulietta 2.0 etc 175 HP TCT
Have you checked the errors in Mes/fes? That way it will be easier to help you when you have the error codes
1. Check engine,
Did you buy a battery for S&S? because any ordinary weak one will also generate errors...
Do you have high mileage?
Back
Top
