    Ramki Alfaholicy
start-up initial RPMs
soszino
Member
Joined
Aug 29, 2013
Messages
47
Location
Car
Mito 1.4 TB 120
Has anyone noticed in the 1.4 t-jet such a peculiarity, that when starting a cold engine after a long idle of a few hours, after a night:
Air temperature 10 degrees or higher the RPMs immediately jump to about 1200 rpm
Air temperature below 5 degrees standard idle RPM around 750 rpm
Starting at a temperature below 5 degrees, driving for x km and then parking the car in a warm garage at a temperature of about 15-18 degrees. Then starting after e.g. 8 hours the engine starts at 750 rpm and after 1-2 seconds abruptly rises to 1200 rpm
Is there any logic to this? :)
I have the interface, I don’t know the program. I don’t know if I am advanced enough to log correctly. What parameters are needed for interpretation?
for the interpretation to be correct, it is enough to log engine RPM, water temperature ECM, ambient temperature IAT, the long LongFT1 parameter and short ShortFT1... I think the Long parameter will be crucial for interpreting the dependencies... The Scan XL version is 3.5.1; there was no newer... I will attach screen captures, soon I will attach config files, the program logs more parameters anyway... program configuration and license info were given in this topic "how to do chip tuning for Giulietta."
http://www.forum.alfaholicy.org/mit...uning_dla_giulietty_1_4_ma_170c_do_190cv.html
p.s. in the screenshot there is longft1 = +2% and V=1450 rpm, ECT, IAT + 13 C.
  • testmito.rar
    testmito.rar
- IAT is cabin temperature, not ambient at least in the Scan XL program..
- after a night IAT will equal ambient temperature.
- in G I did not observe this effect, always from idle, i.e., high RPMs.
That also surprised me once... my Julka always starts on idle and from what I remember even in summer it briefly engaged... (but I’m not sure about summer :P) in cooler days it stays at higher RPMs for about 3 minutes and then drops...
From what I remember it happened only 2 or 3 times at around 3 degrees after the whole night of being outside the engine dropped to low RPMs... a bit surprised me but I didn’t do anything special about it.
Back
Top
