    Ramki Alfaholicy
Radio code 159
Hello,
I would be very grateful if someone could help me with a code :rolleyes:
7 648 321 316
815CM8321b5815156
In this free site from the first posts I couldn't find this model :(
Mine was the same, model not found, but the code turned out to be correct anyway. Try it.
Sent from my HUAWEI GRA-L09 using Tapatalka
Hello,
7 648 321 316
815CM8321b5815156
indeed one number doesn't fit the site but I checked with another random case but keeping your serial number
it returned 4516
check
you don't have to specify the model exactly - I've picked random radios before but the number was correct and the code worked
it returned 4516
check
Ok. I'll take a look calmly. Maybe it will work.
Sent from my F8331 using Tapatalka
Show a photo of the panel.
Panel is standard, only MP3 logo next to the navigator
bocian sprajt Thanks for the help. I re-entered my SN and the code turned out correct. Everything works :edziahurra:
4 packages by courier!!!! address on PM :-) but seriously - it's nice that you started talking
Gentlemen, how to extract the code from a radio with Magneti Marelli navigation as the friend above? I have a dumped flash in binary form.
Gentlemen, is there a chance for help obtaining the code for such a radio???
BP630267654374
7646302316
Alternatively please point me to a reliable site where the code can be obtained.
Thank you in advance for any help :)
Hi, is anyone able to help me with this radio? After disconnecting the battery the fuse blew and of course the previous owner did not add papers :/ I’ve tried to look for info, paste it in and nothing :("
check 6264
I entered in the radio code site a random serial number
a and the part number with default 7 and then the number from your sticker ( 7 735 387 753 )
I was just going to check but unfortunately it doesn't jump. I feel I’m doomed to a service with the electrician costing 200 PLN :/ if someone has any ideas I’d be grateful.
Back
Top
