I checked the fuse for the headlight washers, and after turning the ignition it showed errors like VDC unavailable see handbook, hill holder unavailable see handbook, have power steering checked see handbook. I looked again in the fuse box, but everything is in place and pressed down. There is a Start-Stop system, 2012 model, MultiAir Giullietta, there are steering-angle adaptive lights. Will it sort itself out after a while, or do I need to connect it to a computer, and if so, is there any cheap good one for home use to view the fault and clear it? I also read that the car needs to calibrate somehow because one of the systems could have reset or lost power, and it should just be driven a little.
