    Ramki Alfaholicy
Dancing climate control panel
Krystianj
New
Joined
Dec 10, 2025
Messages
2
Car
Giulietta 1.75 2012
Hi everyone, I don’t even know how to start, I registered on the service because I don’t know where to look anymore, dug through the internet and GPT and what - nothing. The problem we have (and there wasn’t one) concerns the vents. I’ll start with this: a few months ago cold air blew from the right side and warm from another. The topic is known. I handed it to a mechanic, we changed the heater, broken actuators and it works fine. But here the problem now is a lot, a lot more interesting. I’ll describe as best as I can because it isn’t easy. The air conditioning turns on and off whenever it wants. When it’s off, let’s say - When we switch to the windshield, it blows to the chest. When we connect to the windshield and the driver, it blows to the chest. When we switch to feet, nothing happens. When we turn off everything and switch to feet - it still operates to the chest. When the windows fog up and I can’t tell what’s happening, I turn on the closed circuit in the car. The temperature works as it should for both the driver and the passenger (if I set it cool for me and warm for the passenger it works as it should in terms of temperature), so when I turn on the closed circuit, beware... It works on the windshield even though I have the torso on :) and if I switch to feet, you can hear the flaps opening and it blows on the feet but for a second or two and then returns to the windshield or torso. The air conditioning turns on as it wants and whenever it wants. Additionally, the driver's seat with a warming butt also turns on whenever it suits it, I don’t know if it’s related. Where should I start and what to do about it. There have been 3 mechanics, none of them know what’s going on, so mechanics… so to speak.
hi
in a way you answered your question yourself
you didn’t have a problem, now you do
I would start by checking whether you have the actuators set correctly... you say they were replaced
second thing, try calibrating the whole climate control from scratch… (reset)
https://www.youtube.com/watch?v=B6SRrtB7BUw
Okay, a fault appears on the right side, 0.01, how to “set it” in the sense that maybe it was installed incorrectly or what?
That’s not a fault but the result of the test you performed, i.e., 0.01 positive result and 0.02 negative result. It’s best to connect a diagnostic tool (mesa) and check what it spits out :flute:
Back
Top
