    Ramki Alfaholicy
Check engine
Karolaaa
New
Joined
Aug 28, 2016
Messages
48
Location
Poznań, Łowicz
Car
Alfa Romeo MiTo
Hi,
I have a problem with my MiTo. I have a gas installation installed in it, yesterday as usual I filled up at Orlen and after 50 km of driving I got a Check Engine. When I was installing the gas I also had a problem at first when I fueled at some no-name station; the gas installer who fitted the system said it was due to bad quality gas. And for about 17k km it was fine, until yesterday. Dynamic mode does not start (but I understand that), the check engine light stays on, even when I switch to petrol. I have new plugs. Is there a possibility to clear the error myself or should I go to a mechanic? What to do to avoid this problem in the future?
Engine 1.4, STAG installation.
I still have more than half a tank of gas after yesterday’s trip and I think I’ll have to drive it out because I’m not sure mixing would be a good idea. Or perhaps better to mix with another gas?
I don’t know if it would help to disconnect the battery (negative terminal), then calibration of power steering is needed (doing it yourself, turning the wheel max left and max right).
It depends on why the error appeared, because it could be any number of sensors, from which the signal needs DNA.
Sent from my F3211 using Tapatalka
I have Julka with factory LPG and I had exactly the same after filling up at a BP station - unfortunately you can’t clear the error without an interface, but I think your gas installer could help here, perhaps he has a simple interface with which you can clear the "check". After paying 50 PLN for diagnostics and clearing, I started filling at Shell and the problem hasn’t appeared since. I’ll add that the error appeared only at one BP station - at other stations I filled and there was no problem. I think the best long-term option is to invest in a cable and a diagnostic program.
I see you’re in Poznań. If you’re near na Ratowie, I can clear the error and that’s it. If it comes back, a mechanic is necessary, simple as that. PM me if you want.
The best option is to properly tune the LPG.
Wrong adjustment or improper installation or components for LPG that are not properly matched - wait.
On gas, errors related to the composition of the mixture are common.
If it’s a transient error (for example, the gas was lousy but now everything is OK) the light will go out after a few (several) starts.
If it’s constant, it won’t disappear by itself; the computer won’t help much because soon it will come back. The computer will show what’s going on (though interpreting the error is another broad topic).
Of course, when the MIL is on you can’t enable D mode.
I suggest driving a bit on petrol.
The ECU can cope with some changes in fuel parameters, but if the gas isn’t tuned well it cannot shorten or lengthen the injection time enough to achieve the proper mixture and will throw MIL.
If it’s constant, it won’t disappear by itself; the computer won’t help much because soon it will appear again. The computer will show what’s going on (though interpretation of the error is also a broad topic).
Of course, when MIL is on you can’t enable D mode.
The ECU can handle changes in fuel parameters to some extent, but when the gas is not adjusted correctly it cannot shorten or lengthen the injection time enough to achieve the proper mixture and it will throw MIL.
Thanks for the info. I’m thinking about switching back to petrol, but that probably won’t solve my problem for long – I still have half a tank of that unfortunate gas. After refueling and driving 20 km the indicator lit up again, so I suspect it’s the gas. I always fill at Orlen and there was no problem, now I pulled up and there it is. :(
How much could I get such a device for private use? How do you even search for it, what is it called?
Wrong adjustment or wrong installation or components for LPG not properly matched - wait.
I had gas fitted half a year ago – during that time I drove about 20k km and there were no problems. So bad installation is unlikely. And the adjustment.. The engine runs well, slightly differently than on petrol but it doesn’t jerk and doesn’t choke. It was like this at the beginning but maybe you don’t notice it?
Hardware: ELM 327 interface for a few dozen zlotys
Software: alfaobd or fiat ecuscan (paid; several groups dedicated to Fiat allow handling all modules), but basic diagnostics, reading fault codes and turning off the light can be done with some free tool (I can’t recall the name right now but there are lots of them)
Back
Top
