waldi102
New
- Joined
- Sep 12, 2013
- Messages
- 85
- Car
- Alfa Romeo 159 SW 1,9 JTDM
Since September 9 I have been a happy owner of an Alfa 159 SW.
Because I back out of my property and the rear view is terrible, I decided to improve the factory lighting.
To carry out this operation I decided to use 2 LED lamps, which I bought to install daytime running lights in my old camper. I didn’t install these lamps because it turned out they don’t have homologation.
Because improving the rear lighting makes no sense since it can’t be seen in the car’s rearview mirrors anyway. I concluded that the only thing I can improve is the illumination of the ground just behind the rear wheels.
If we already have LEDs, they should be placed somehow sensibly so that they light the sides of the car. I decided that the best place would be the external bottom of the spare wheel well. I stuck the LEDs with Sikaflex at the very bottom so that the lamps face the sides. I powered them in parallel to the reverse lamp bulb.
After removing the plastic doors in the trunk on the right side and disconnecting the plastic cap that provides access to the rear lamps, you can see the wiring harness. The thick black wire is ground. and the thick green wire going up to the tailgate is the power line from the reverse lamps. I did it not very technically, but it certainly won’t break. I scraped both wires of insulation for about 1 cm. I soldered the LED wire and insulated the whole thing. I brought the LED wire down through the technical hole, which is sealed with a black rubber plug. The LED wire should of course be properly fixed. I attached it with hose clamps to the fuel line. PS electrical connections under the chassis, if you need to make such connections for short wires near the LEDs, it’s best to solder and insulate with heat-shrink tubes.
Good luck
Good luck
