D
dobry człowiek
Guest
Hello everyone. I once had a problem when locking the car with the remote—the indicators shorted. I went to a service in Tarnów and it turned out that in the trunk, behind the battery mount, that is behind a plate on the left side, there is a small relay. It’s enough to take it apart and clean the contacts, and the fault is fixed. And the service charged 150 PLN for it.
You need to remove the left side panel, take out the battery, unscrew the plate on which the battery sits, and there is that relay; you have to take it apart and clean the contacts with sandpaper.
